There was an update made to ArcGIS Online last night, and as part of that update the 'Open in Explorer Online' option was removed. You can read about the other updates made at the following link:http://resources.arcgis.com/en/help/arcgisonline/#/What_s_new/010q00000006000000/
I just got off the phone with ESRI tech support and the suggested workaround was to start using the parcel viewer app template instead of the ArcGIS App for iOs that we have deployed to all our field crews. I'd rather not change everything up here and I really don't want to republish everything to feature services (as they said was required to get the queries to work with the parcel viewer app), but we've got to have the predefined searches in the ArcGIS app. Am I hearing that if we hang tight, we will be able to create these in the basic arcgis.com map? I still can access the existing maps and queries in explorer online (good) but I saved a map this morning in arcGIS.com and when I tried to open it in Explorer, I got error message "Unsupported webmap version number (1.9.1). Is the solution to not edit/save maps in arcgis.com for now? Only use arcgis explorer to save and edit queries? Please advise. Thanks
Hi Aaron,We understand the workflow and need to create predefined queries in Explorer Online, and will be adding it to the Map Viewer in a future release. You can continue to use Explorer to create queries by visiting the following URL http://www.arcgis.com/explorer/The application will not be pulled off the web until this capability is replaced.Thank you,Andrew
The Parcel Viewer is not the solution we are providing in response to predefined queries created in Explorer Online, it is just another option you can use at this time to query data from a service.ArcGIS Explorer Online is still available on the web, for workflows that require the use of predefined queries authored in Explorer Online and used in Explorer or in the ArcGIS for iOS or Android applications. For several technology reasons we are making these changes, and will be providing a better workflow to author queries and consume them in all the applications in a future release. Until this option is available I would encourage you to bookmark http://www.arcgis.com/explorer in your browser, so you can continue to create predefined queries to use as needed. *Please note you cannot open web maps recently created with the Map Viewer, but can author new or modify existing.Another option available now for searching features is to create and host an ArcGIS for Server Geocode Service that contains locators built off your feature classes and adding it to your Organization. You can try an example of this that I have here by searching on 'Jack Nicklaus Tribute Sculpture' as suggested in the search box. Please visit the online help for more information on adding your custom geocoder.We do understand the importance of the application and functionality to you, and is why we are making these changes to help you build sustainable solutions that will work in all the available applications. Thank you,Andrew
