I've been trying to configure our rest-config to utilize an internal JavaScript API setup on a 10.2 server instance using the Web Adaptor for Tomcat with no luck. I've changed the rest-config.properties file for the internal Tomcat instance for jsapi.arcgis and jsapi.arcgis.css, restarted the Tomcat service, and I'm still not having any luck viewing services in JS viewer. I've also tried to change the ArcGIS.com URL to an internal portal instance with no success. The REST services directory continues to display "ArcGIS.com Map". If I pull those URLs into a browser they come up with no issues.Is there a trick to getting this to work properly at 10.2?......
