Hello, I want to report a problem:
Sometimes when a polygon is created in a shapefile layer and not in a geodatabase, the element disappears from the map but its properties are saved in the attribute table. I use ArcGIS Pro 3.2.
Hmmmm...that's very strange. I mimiced the workflow that you had in your video with zero errors. Sometimes when I see strange behavior like this, I rename the Esri folder in two locations to ESRI__OLD. Those locations are:
C:/users/<user_profile>/appdata/local
C:/users/<user_profile>/appdata/roaming
Does the issue persist?
