Timothy,You've got the correct workflow. As long as the current string field contains only numbers, you can create a new field (type double) and use the field calculator to populate it with the values from your string field.Your only other option would be to create a new feature class with the proper field schema and load your data into it (using field mapping to make sure your data ends up in the proper fields).
Hi Tim,
Thanks for the answer.
What if my string column contains no only numbers but also blanks (#DIV/0!)?
Is there a way to convert the blanks (#DIV/0!) to 'Null's instead of '0's at the same time?
Cheers.
Alternatively, you can use the "Show Codeblock" in the field calculator and then use
Output = CDbl( [lFIELDNAME])
[Field] = Output
CDbl converts the string to double.
You can then add more items such as Replace as well to remove items such as periods or decimals if need be
e.g.
Output = CDbl( Replace([FIELDNAME],"."," "))
If you want anything that is NOT a numeric number in the text field to show up as NULL in the double field, This works:
Id do a check to make sure ISNumeric, if not then output Null.
Dim String, Check
String = [STRINGFIELD]
Check = IsNumeric(String)
If Check = True then
Output = CDbl(String)
else
Output = null
End if
[FIELD] = Output
<null> will be what you see in the double field.
Thanks Michael,
I am not really familiar with VB Script. I followed your method but it turns out 'failure during processing'.
Please tell me how to resolve this problem.
hi Golden,
First you need to Check "Show Codeblock"
that entire block of code you have there you put in Block #1 as seen above
then you need to type Output in Block #2.
Hi Golden.
There is nothing wrong with the code.
The issue here is not understanding data in general and/or the code....
In this case, let me try to provide a 'crash course' on some items.
Null means one thing and is handled differently for SQL and is different for data in a FileGeoDatabase and again different in a dbf standalone and yet again different for xlsx etc...
What does this all mean? It means, an understanding of data and its storage media is needed. Below I have made some case examples.
Follow:
Create a table in a FileGeoDatabase.
Catalog >> New .. >> Table (in the file geodatabase)
Create two fields, STRINGS - with a TEXT data type and DOUBLES using Double
Add a few sample Strings...
Right click on FIELD >> Calculate
(Show Codeblock) (VBScript)
Pre-Logic:
String = [STRINGS]
Doubles= Output
so should look like this:
Once you run it...
Anything NOT a numeric is now <Null>.
Looks great! You could from here export to xlsx for example, without issue.
Ok, lets try a Shapefile or dBASE standalone table.
Here it what happens if it runs on a Shapefile:
You can see the results as well, warning that there was an Empty value ( meaning <null>). We know that this is on the Double field because we understand that <null> is not possible in a shapefile environment. (I wont get into details as to why) but you can look and you will see via any means (SQL manager or ArcCatalog or in .accdb that on a double field, there are options to Allow NULL Values.
So the warning means, empty value was inserted with what is only possible with a double field in a shapefile... a Zero.
we could write more VBScript to alleviate the warning message when it runs (what is called error encapsulation / handling) if we wanted.
Now what I didn't notice when I quickly replied is that it appears that the featureclass is JOINED to an xlsx? (not entirely sure)
in which case, <null> is not supported.
If you are working directly off a xlsx in ArcMap.
Doubles should show <null>
Of course then there is no field calculations...
So then this becomes a question of 'what are you trying to accomplish'.
if you want <null> for a featureclass, then the featureclass needs to be in an Enterprise Geodatabase or a FileGeodatabase (and a few other data container types).
It doesn't end here either, I could keep assuming (which isn't good) (e.g are you calculating a Joined Featureclass to export to xlsx? ) ... so Ill stop here, hopefully this makes sense and works for whatever you are trying to accomplish.
Well this is weird. For a minute I thought I had forgotten how to code in the last 7 years, but quickly realised that my name sake had just helped me out, thanks!!
