I have an SD file that, when I try to deploy it to the ArcGIS Server, generates the following two errors:Failed to upload service item information for 'myfolder/myservice.ImageServer'. Folder path cannot contain relative path such as .. or .
Method failed.HRESULT = 0x80040208 : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT.
We have a cluster of two ArcGIS Servers. These errors appear twice on the same machine. The other machine, although it gets requests about this deployment (I can see from its logs), doesn't appear to try to do as much with it...there's just a series of REST request/responses with no additional info and no suggestion of a problem. Whereas, on the first machine, it is obviously processing the file. It shows the upload occurring and a number of steps before saying "Service 'myfolder/myservice.ImageServer' was created successfully". Then, the very next two messages are the ones shown above.From ArcGIS Server Manager, the service appears to be deployed and running. However, it crashes frequently and in trying to figure out why, I've observed above.The SD was created in ArcCatalog from a GDB where the mosaic is defined using "Share as Image Service". Before creating the SD, I "Modify/Repair" the paths to point to the location of the images that is accessible from the ArcGIS Server. I can't find any other paths that might be considered relative unless it is considering the New Path relative because it is a UNIX path that starts with "/". Our ArcGIS Servers are on Linux and the accessible path to the images means starting at the root.If it is, indeed, this path that is causing the problem in the deployment, can anyone suggest a solution?Alternatively, can anyone suggest somewhere I can look within the GDB itself or during the generation of the SD for some other path that might be causing the problem?Cheers,jtmMore details learned:1. I've learned this has nothing to do with the mosaic. I get the same messages no matter what I try to deploy ... a map service, a geoprocessing service, an image service.2. Just before the first pair of error messages, there is a message: "Adding item information card to service"; and, just before the second pair of error messages, there is a message: "Adding manifest to configuration store." I'm guessing, then, that it is these operations that are failing and generating the errors.In looking into these further I started reading about the "Search" services in regards to the adding info one (http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000383000000). Could all this be related to that in some way? I found an empty .dat file under the arcgissystem/arcgisindex/.site directory and the documentation says these are only supported on Windows systems. Could some instruction still be trying to write to something anyway?Still haven't figured out the configuration store/manifest thing might be referring to, though. Anyone with ideas, please share...
