I am wondering if anyone has any experience with this workflow. I have a table from our CAMA software and I would like to copy some attributes from that table into the Records table using an attribute rule. Basically, if the parcel number in the CAMA table matches the parcel number in the Records table, then populate the specific field in the Records table with the legal description. The CAMA table is in the same FDGB as the Records. I have the Arcade code attached. It runs without errors but when I make an edit in the records, the field with the rule just returns Null. I would like to set up other rules similar to this so that CAMA data comes over much quicker.
