How to export field names and field descriptions of a featureclass?
arcpy.ListFields() will give you a list of field names: ListFields—ArcPy Functions | ArcGIS Desktop
if by description you mean type, that's in there too....
<SPAN class="keyword token">import</SPAN> arcpy fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'N:\GIS\Geocoding\Geodata.gdb\rawAddresses'</SPAN> <SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="string token">'{field.name} {field.type} {field.length}'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#returns a list that looks like this:</SPAN> OBJECTID OID <SPAN class="number token">4</SPAN> ADDR_HN String <SPAN class="number token">12</SPAN> ADDR_PD String <SPAN class="number token">12</SPAN> ADDR_SN String <SPAN class="number token">60</SPAN> ADDR_ST String <SPAN class="number token">40</SPAN> ADDR_SD String <SPAN class="number token">12</SPAN> PARCEL String <SPAN class="number token">30</SPAN> UNIT_DESIG String <SPAN class="number token">10</SPAN> BLDG_DESIG String <SPAN class="number token">10</SPAN> ADDRESS String <SPAN class="number token">45</SPAN> IDENTIFY String <SPAN class="number token">75</SPAN> ADDR_LABEL String <SPAN class="number token">65</SPAN> CITY String <SPAN class="number token">30</SPAN> ZIP_CODE String <SPAN class="number token">10</SPAN> CORNER_ADDRESS String <SPAN class="number token">70</SPAN> PLAT_NUM String <SPAN class="number token">15</SPAN> SUB_PLAT String <SPAN class="number token">70</SPAN> LOT_NUM String <SPAN class="number token">15</SPAN> BLOCK_NUM String <SPAN class="number token">10</SPAN> DEVELOPMENT String <SPAN class="number token">75</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
