I would like to ask a question about Experience Builder on AGOL.
My project has a layer with time enabled referring to four unique times, which in this case are 4 unique years (2010, 2013, 2016 and 2020). In this project, a Timeline (Timeline Widget), was inserted for this layer. However, there is also a filter (Filter Widget), linked to this same layer. In this filter, the idea is to filter by year.
Unfortunately, there is a problem: As the same layer is being used in the Timeline Widget, the Widget filter only makes available the year that is active in the Timeline. Only when the Timeline is disabled using the "I" button is that the Filter Widget make available all the years present in the layer.
The data (years) available in the Widget filter are "stuck" to the year of the Timeline Widget. As you can see in the print below, just 2010 is available in the Filter Widget, as the Timeline is Activate and stuck in 2010.
I would like to know if there is any way to keep all years active in the Filter widget, without taking into account the year that is active in the Timeline.
Renata
