The number field in the Survey 123 Website is just that. A number field. I know there are ways to manipulate it using Survey 123 Connect, but a couple of simple things might be easy to add to the website. As for the commas in the number field, I know in Survey 123 Connect the commas for 1000s separators can be turned on or off. Why not on the website? The Single Line Text field allows masks to be added such as (xyz) xyz-xyz ext. xyz, but not the number field. If it is to be used for a phone number the problem is all you can get is 5,555,555,555. No dashes or parenthesis or even spaces not to mention if you wanted to use a monetary symbol ($)! While a text field even with a mask can be like (Are) You-Okay.
I have created a Survey 123 Connect that went to the extent of pages, groups, multichoice tables, relevant questions, and 3 languages. So not simple but not outlandish especially for the first time. I just don't want to have to use Connect to put in a phone number or dollar amount. Thanks!
