Public Sub ConvertShapefileToFCSDE() ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.Engine) Dim aoInitialize As IAoInitialize aoInitialize = New AoInitialize aoInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeEngine) ' Open the source and target workspaces. Dim sourceWorkspacePath As String = "C:\projek peta melaka" Dim pProp As IPropertySet = New PropertySet Dim wFac As New SdeWorkspaceFactory Dim targetWorkspace As IWorkspace Dim targetWsPath As String = "Provider=SQLNCLI10;" + _ "Data Source=" + My.Settings.Server + ";" + _ "Initial Catalog=" + My.Settings.Database + ";" + _ "User ID=" + My.Settings.User + ";" + _ "Password=" + My.Settings.Password + ";" pProp.SetProperty("Server", My.Settings.Server) pProp.SetProperty("Instance", My.Settings.Instance) pProp.SetProperty("Database", My.Settings.Database) pProp.SetProperty("User", My.Settings.User) pProp.SetProperty("Password", My.Settings.Password) pProp.SetProperty("Version", My.Settings.Version) targetWorkspace = wFac.Open(pProp, 0) WS = targetWorkspace 'Dim targetWorkspacePath As String = "C:\projek peta melaka\Melaka.gdb" Dim sourceWorkspaceFactory As IWorkspaceFactory = New ShapefileWorkspaceFactoryClass() Dim targetWorkspaceFactory As IWorkspaceFactory = New FileGDBWorkspaceFactoryClass() Dim sourceWorkspace As IWorkspace = sourceWorkspaceFactory.OpenFromFile(sourceWorkspacePath, 0) 'Dim targetWorkspace As IWorkspace = targetWorkspaceFactory.Open(targetWsPath, 0) ' Cast the workspaces to the IDataset interface and get name objects. Dim sourceWorkspaceDataset As IDataset = CType(sourceWorkspace, IDataset) Dim targetWorkspaceDataset As IDataset = CType(targetWorkspace, IDataset) Dim sourceWorkspaceDatasetName As IName = sourceWorkspaceDataset.FullName Dim targetWorkspaceDatasetName As IName = targetWorkspaceDataset.FullName Dim sourceWorkspaceName As IWorkspaceName = CType(sourceWorkspaceDatasetName, IWorkspaceName) Dim targetWorkspaceName As IWorkspaceName = CType(targetWorkspaceDatasetName, IWorkspaceName) ' Create a name object for the shapefile and cast it to the IDatasetName interface. Dim sourceFeatureClassName As IFeatureClassName = New FeatureClassNameClass() Dim sourceDatasetName As IDatasetName = CType(sourceFeatureClassName, IDatasetName) sourceDatasetName.Name = "tsempdm.shp" sourceDatasetName.WorkspaceName = sourceWorkspaceName ' Create a name object for the FGDB feature class and cast it to the IDatasetName interface. Dim targetFeatureClassName As IFeatureClassName = New FeatureClassNameClass() Dim targetDatasetName As IDatasetName = CType(targetFeatureClassName, IDatasetName) targetDatasetName.Name = "tsemp" targetDatasetName.WorkspaceName = targetWorkspaceName ' Open source feature class to get field definitions. Dim sourceName As IName = CType(sourceFeatureClassName, IName) Dim sourceFeatureClass As IFeatureClass = CType(sourceName.Open(), IFeatureClass) ' Create the objects and references necessary for field validation. Dim fieldChecker As IFieldChecker = New FieldCheckerClass() Dim sourceFields As IFields = sourceFeatureClass.Fields Dim targetFields As IFields = Nothing Dim enumFieldError As IEnumFieldError = Nothing ' Set the required properties for the IFieldChecker interface. fieldChecker.InputWorkspace = sourceWorkspace fieldChecker.ValidateWorkspace = targetWorkspace ' Validate the fields and check for errors. fieldChecker.Validate(sourceFields, enumFieldError, targetFields) If Not enumFieldError Is Nothing Then ' Handle the errors in a way appropriate to your application. Console.WriteLine("Errors were encountered during field validation.") End If ' Find the shape field. Dim shapeFieldName As String = sourceFeatureClass.ShapeFieldName Dim shapeFieldIndex As Integer = sourceFeatureClass.FindField(shapeFieldName) Dim shapeField As IField = sourceFields.Field(shapeFieldIndex) ' Get the geometry definition from the shape field and clone it. Dim geometryDef As IGeometryDef = shapeField.GeometryDef Dim geometryDefClone As IClone = CType(geometryDef, IClone) Dim targetGeometryDefClone As IClone = geometryDefClone.Clone() Dim targetGeometryDef As IGeometryDef = CType(targetGeometryDefClone, IGeometryDef) '----------- ' Cast the IGeometryDef to the IGeometryDefEdit interface. Dim targetGeometryDefEdit As IGeometryDefEdit = CType(targetGeometryDef, IGeometryDefEdit) ' Set the IGeometryDefEdit properties. targetGeometryDefEdit.GridCount_2 = 1 targetGeometryDefEdit.GridSize_2(0) = 0.75 ' Create the converter and run the conversion. Dim featureDataConverter As IFeatureDataConverter = New FeatureDataConverterClass() Dim enumInvalidObject As IEnumInvalidObject = featureDataConverter.ConvertFeatureClass(sourceFeatureClassName, Nothing, Nothing, targetFeatureClassName, targetGeometryDef, targetFields, "", 1000, 0) ' Check for errors. Dim invalidObjectInfo As IInvalidObjectInfo = Nothing enumInvalidObject.Reset() Do While Not (invalidObjectInfo) Is Nothing ' Handle the errors in a way appropriate to the application. Console.WriteLine("Errors occurred for the following feature: {0}", invalidObjectInfo.InvalidObjectID) invalidObjectInfo = enumInvalidObject.Next() Loop End Sub
