We have an experience builder application built out in our dev environment for portal. We will want to move through environments with this same application without rebuilding it. How do you do this without having to rebuild widgets? Our data url for each environment is different and when you change data sources it breaks your widgets you had built. Surely there has to be a way around rebuilding these every time? Thanks!
