Hi David,
The key to this type of analysis is to set the geoprocessing environments; the extent, cellsize, spatial reference, etc that will be used in the analysis. Important are:
This should be done, before converting vector data to raster and will force the data to use the same extent. By default many raster tools will use an output extent that is the intersection of the input extents of the rasters.
I am not able to see the images you zipped and attached to your post. Consider to include the images in the post the next time and not zip and attach them. This makes it a lot easier and faster to see what you mean.
The merge tool is used to merge adjacent data and not to sum pixel values. The Cell statistics tool can be used for that purpose, but make sure that the "Ignore NoData in calculation" is checked to avoid NoData to propagate in the result. Read this topic for more information on NoData cells: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Please note that when doing cost distance calculations that the rasters that make up the cost raster, cover the entire extent, otherwise lower cost values will influence the route calculated since the cost will result in a lower value.
Kind regards, Xander
