My understanding is if the name of the machine shown within the portaladmin/machines endpoints changes, the Portal for ArcGIS site will become unavailable. To prevent this issue from occurring, I've allocated and assigned an elastic IP address to the EC2 instances where I'm installing Portal for ArcGIS.
On a RHEL 8x EC2 instance, following all of the steps in "If your portal machine has multiple network interface controller cards" section of this doc Installing Portal for ArcGIS—ArcGIS Enterprise | Documentation for ArcGIS Enterprise and step 7 in this doc: Deploy a base ArcGIS Enterprise portal on AWS—ArcGIS Enterprise in the cloud | Documentation for ArcGIS Enterprise results in site creation failure. I set the following:
- Created hostname.properties file and added hostname=<elastic IP>
- In hostidentifier.properties file, uncommented preferredidentifier=ip
- In the hostidentifier.properties file uncommented and modified to hostidentifier=<elastic IP>
Which of these files are which specific properties need to be set to force the Portal for ArcGIS site to use the elastic IP address to prevent future issues caused my private IP address changes?
Thank you!
