Is it possible to change/set the ViewCount of an Portal-Item? Had to recreate a corrupt item and was wondering if I could set the viewcount to that one from the old corrupt item.
Andi
Thanks for the reply.
Still curious for the long answer 🙂I guess short "not via Python-/ Rest-API etc." and long "direct on the item-portalserver-folder or the database which you should not touch"?Â
The short answer is no, it's not possible.
Because you created a new item, even though it's identical to the original, Portal still sees it as new and starts the view count back at zero.
