I upgraded to 3.2 in order to access the upgrade arcgis module. However I can't seem to upgrade my previous environment. Is it necessary to create a new clone?
> "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda-proup.exe" --prefix "C:\Users\tbott\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone" --force --backup "C:\Users\tbott\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone.tar.bz2"
Collecting packages...
Upgrading environment at 'C:\\Users\\tbott\\AppData\\Local\\ESRI\\conda\\envs\\arcgispro-py3-clone' with backup at C:\Users\tbott\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone.tar.bz2
Detected packages added to environment:
conda: tabulate geopandas
File "conda_proup\core.py", line 580, in backup
File "conda_pack\core.py", line 561, in pack
File "conda_pack\core.py", line 396, in pack
File "conda_pack\core.py", line 1095, in add
PermissionError: [Errno 13] Permission denied: 'C:\\Users\\tbott\\AppData\\Local\\ESRI\\conda\\envs\\arcgispro-py3-clone\\Scripts/normalizer.exe'
The above exception was the direct cause of the following exception:
File "conda_proup\cli.py", line 64, in main
File "conda_proup\core.py", line 1082, in upgrade
File "conda_proup\core.py", line 997, in upgrade
File "conda_proup\core.py", line 583, in backup
Exception: Unable to backup original environment, stopping upgrade.
Backing up environment to C:\Users\tbott\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone.tar.bz2
Packing environment at 'C:\\Users\\tbott\\AppData\\Local\\ESRI\\conda\\envs\\arcgispro-py3-clone' to 'C:\\Users\\tbott\\AppData\\Local\\ESRI\\conda\\envs\\arcgispro-py3-clone.tar.bz2
I'm getting a 'Permission denied.' I don't have admin rights on my machine but this should be an issue. I was able to clone the environment previously and manipulate packages as necessary.
Attempting to do so at the command line doesn't seem to like the syntax of the provided code.
