Unsupported query - using type: blob. https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-Field.html#type
Documentation:
Possible Values:"small-integer"|"integer"|"big-integer"|"single"|"double"|"long"|"string"|"date"|"date-only"|"time-only"|"timestamp-offset"|"oid"|"geometry"|"blob"|"raster"|"guid"|"global-id"|"xml"
Hi there,
Ah yes this is a known issue at 4.28. This issue will be addressed in 4.29 and the fix is already in `next`. You can update your codepen to point to <script src="https://js.arcgis.com/next/"></script> to check the fix.
Hope this helps,
