I have seven fields representing the days of weeks. They are Zero or One and I want to color the data based on the One's. I can only add three Fields to the Symbology / Unique Values area. If I could add all seven, I would be fine. Any ideas?
If you use a Custom Arcade expression for Field 1, you can do this. For Field 1, click the "x" to the right of the dropdown menu. In the expression box, copy this script (modify if needed) and paste into the box. Check the syntax by clicking the green check.
var field1 = $feature.Monday;var field2 = $feature.Tuesday;var field3 = $feature.Wednesday;var field4 = $feature.Thursday;var field5 = $feature.Friday;var field6 = $feature.Saturday;var field7 = $feature.Sunday;
return When(field1 == 1, 'Monday',field2 == 1, 'Tuesday',field3 == 1, 'Wednesday',field4 == 1, 'Thursday',field5 == 1, 'Friday',field6 == 1, 'Saturday',field7 == 1, 'Sunday','NoSymbol');
My ArcGIS Pro then shows 7 unique values based upon 1's and 0's from the days of the week attribute fields.
Thanks. I haven't delved into Expression builder much yet. This should work nice!
