Would be great to be able to export data from dashboards,that were generated from multiple FeatureSets using data expressions.Data would be exported as csv.
I believe that I have found a solution.
It involves using the ArcGIS Online Assistant to edit the dashboard JSON. I have used the ArcGIS Online Assistant before with mixed results. I strongly suggest that you make a copy of your dashboard before making these edits. I have only tested it using Tables that display arcade generated features. I offer no guarantees. Here's the process that I used:
First get the item id of the dashboard and the name of the table (Edit Dashboard: Table: General: Settings: Name).
Then open ArcGIS Online Assistant https://ago-assistant.esri.com/ and log in.
This is working for me for both privately and publically shared dashboards.
I hope it works for you.
This would be extremely helpful.
This is the number one thing users of the Dashboards I built have been requesting. I built custom tables for them with expressions to view on the dashboard and they want to be able to export it and add it to other reports.
+1 this is really the functionality I was looking for when after data summary download was added. We can download the layer data easily enough, what would be great is if we could export custom feature sets (summary table, not the source datasets)
The link referenced above confirms that downloading is not currently supported on data generated from data expressions. I guess this is because there could be some quite complex logic pulling data from multiple sources and it would be harder to check all those have export enabled.
Would be a very useful addition to support this.
hi @MajidAlabrawi1
At the moment it will just work for hosted feature layers as you are problably mentioning, but not for featureSets that are generated with arcade data expressions. In this particular case there are not options to download the data.
hi @Juan_FelipeVillegas ,
i am sure you can find this in arcgis enterprise 11.1 also AGO
check this Download data—ArcGIS Dashboards | Documentation
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
