It would be create create a bar chart using a date field.
This would be for a chart that has an x axis for dates with a reporting period like by day, week, month, or year. Thinking something similar to what ArcGIS dashboards can do.
@mklatt_cityofventura_ca_gov Thanks for posting the idea. We will consider this.
However, this should be possible to use the data components that are calculated by insights and using a cross filter on 2 or more charts.
Note that the cross filter Akshay mentions allows you to take the functionality further.For like-for-like functionality with what you mention from Dashboards all you need do is select a date-time component such as Month from the data pane, and drag that to a bar or column chart.
Thank you! the idea would be to have mulitple years on the same chart visualized by year/month.
Currently I use a calculated field and that gets the job done, but is not ideal.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
