After I click the search button on Robert's widget, I'd like the mouse to revert back to the pan tool so I can scoot around the map and see the selected points. It currently stays with the action to select more features.I think I need to do something to the function queryFeaturesGra(), along the lines of navTool.activate. That once a graphic search is excuted, the mouse changes to pan.Any chance you know?
Hi all - Is it possible to show different records in the results and popup windows using the Esearch Widget? I'd like to show just one or two fields in the results window, but then show all 10 fields in the popup window, including any attachments. The xml Robert provided is helpful with showing or not showing on the datagrid etc, but was wondering if I'm missing a popup component.Thanks, Meg
More on this.in the eSearchWidget.xml I have <disablebuttons>grid,spatial,datagrid,graphic</disablebuttons> set.also, along with disabling the showStateResult, I moved the loader up to the text area as per here:http://forums.arcgis.com/threads/64335-eSearch-disable-Results-state?p=223600#post223600This way, I only have the text search options and no other icons across the top. The loader function shows the spinner while loading, then, after load is done, it gives you the total number selected but you never navigate away from the initial search box so are ready for the next search.[ATTACH=CONFIG]18867[/ATTACH]R_
<layer label="Post-closure" type="dynamic" visible="true" alpha="1.0" url="http://gis01.wch-rcc.com/ArcGIS/rest/services/SDCV_custom/post_closure/MapServer"> <sublayer id="2" popupconfig="popups/PopUp_wastepolys.xml"/> <sublayer id="0" popupconfig="popups/PopUp_wastepoints.xml"/> <sublayer id="1" popupconfig="popups/PopUp_wastelines.xml"/> </layer>
if(!disGrid){ wTemplate.addTitlebarButton(ICON_URL + "i_table.png", resultsLabel, showStateResults); }
