I can get the value from the map and put it into a text element. But that will require me to write more logic handling the scale changes. Is there a component I can use?
You can create a Dynamic Text element to write out the Map Frame's scale.
var layout = LayoutView.Active.Layout; if (layout == null) return; //Construct the dynamic text string. //You can create the dynamic text in the UI to get a hint as to how to compose the string in code. String title = @"Scale: <dyn type=""mapFrame"" name=""Map Frame"" property=""scale"" preStr=""1:""/>"; Coordinate2D llTitle = new Coordinate2D(6, 2.5); await QueuedTask.Run( () => { TextElement titleGraphics = ElementFactory.Instance.CreateTextGraphicElement( layout, TextType.RectangleParagraph, llTitle.ToMapPoint(), null, title) as TextElement; });
