I added an AGOL web map in the "linked content" tab in Survey123 Connect.
When I go the the "map" tab, the map doesn't load. It loads if I select any other basemaps.
I added a geopoint question to my form with "map=xyz" under body::esri:style. When testing the form, the custom basemap also does not load, but works when selecting any other basemaps.
When publishing this form, the map also doesn't load on Survey123 for Android, but it does load on the web app.
Any parameter I should add for it to load in Connect and mobile app?
Thanks!
