Hi. I'm trying to prevent submission when a duplicate value is entered into a free text field. I tried adding a constraint to the field with the instructions here: Add a unique constraint to a field—ArcGIS Online Help | Documentation
But I don't have the edit button on the unique field. Help please!
Hi. pulldata("@layer") may work for you.
Here is some background info: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-layer/ba-p/1224415
I attached an example below for clarity. To use the example:
Hope it helps.
I'm getting the following error in the field. I'm not sure what I'm doing wrong. When I test out the survey the field that should be pulling the data is blank.
SyntaxError: Invalid regular expression flag 'n' in expression
Here is the code:
pulldata("@layer", "getValue", "attributes.free_text", "layerURL", concat("free_text ='",${free_text},"'"))
