Bit of a reverse of a common question.
Is it possible to connect a file GDB to MS Access, either to feed data or to use it as an interface?
It seems like Access doesn't recognize file GDBs by itself, but I was thinking maybe using ODBC?
Develop an ODBC driver for the esri File Geodataba... - Esri Community
There was also this question, where someone says it'd be possible to make one using the API, but not sure if anyone ever did that FGDB ODBC driver? - Esri Community
