I've imported a grib file as a multidimensional raster layer (2 variables, whole globe (land) covered over 30 years). Now I need to only export data for the African continent. I've tried the "Clip (Data Management)" and the "Subset Multidimensional Raster" tools.
The first tool allows me to clip the output to the actual shape of the continent, but it removes the time dimension and I'm left with two data points per cell.
The latter keeps the time dimension but I cannot clip it to the actual shape, but only to a rectangle which means that the arabian peninsula is included, but it shouldn't.
I'm using Africa_Countries (generalized) which I found in the portal.
Is there a way to achieve what I'm after?
Alternatively, even more informative would be a way to export the country code as a variable coded to the same cells I'm using in my multidimensional raster layer.
