I have large data and created hosted layers to create an operational dashboard. I have activated the refresh interval on the visualisation but the refresh interval is not working. Can someone advise what to do?
@DrJumaKhudonazarov
This demo helped me a lot. Hopefully, it helps yiou as well.
Automate Updates to Your Web Feature Layers Without Scripting - YouTube
Regards, Mark
Again can someone please help I have tried 3 options:
1, Activated refresh interval in visualisation when creating hosted future layer didn't work
2. Used survey weblink-didn't work
3. Update hosted layers - didn't work
Can someone please help ????
I am having a similar problem. My data is connected to an Azure SQL database. I have replication interval turned on in both the web map and the hosted feature layer. The data updates in ArcGIS Pro but not the ArcGIS Online Web Map or hosted feature layer. Please help.
1) If you do a manual web browser refresh on the dashboard, does the survey layer update? NO
2) If you wait long enough (an hour, whatever), does the survey layer update in the dashboard? NO
3) Is the survey layer publicly shared? I noticed that there's an option in the hosted layer settings for CDP replication interval Tried didn't work
Thanks, i think your point 3 may be the reason and I will check that very helpful tips
I don't have an immediate answer, but I'll ask some questions if you don't mind.
Chip
