I'm attempting to follow the ESRI example (found here) of adding an OpenSearch end point to GeoPortal. I believe I've followed all of the steps faithfully, but when I use GeoPortal to search only the new NSIDC source I get the message:
Unable to load /geoportal/rest/find/document?rid=nsidc&ridName=National%20Snow%20and%20Ice%20Data%20Center&rids=nsidc&searchText=water&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults&dojo.preventCache=1406049254363 status:500/geoportal/rest/find/document?rid=nsidc&ridName=National%20Snow%20and%20Ice%20Data%20Center&rids=nsidc&searchText=water&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults
Clicking on the link I get the same error from Tomcat:
HTTP Status 500 - Error while getting items from repository with id of nsidcCould not get record from db with rid = nsidc
type: Status report
message: Error while getting items from repository with id of nsidcCould not get record from db with rid = nsidc
description: The server encountered an internal error that prevented it from fulfilling this request.
Apache Tomcat/6.0.41
Watching the the gpt log, I see the following stack trace when I search for "water"
Jul 22, 2014 1:17:07 PM com.esri.gpt.catalog.search.SearchFilterKeyword setSearchText
FINE: search text value posted
FINE: search text value posted water
Jul 22, 2014 1:17:07 PM com.esri.gpt.catalog.search.GptRepository readHarvestRecords
INFO: DB Query SELECT PROTOCOL_TYPE, HOST_URL, PROTOCOL, TITLE, DOCUUID, ID FROM GPT_RESOURCE WHERE UPPER(TITLE)= ? AND ((APPROVALSTATUS = 'approved') OR (APPROVALSTATUS = 'reviewed')) AND SEARCHABLE = 'true'
Jul 22, 2014 1:17:07 PM com.esri.gpt.framework.sql.DatabaseReference openConnection
FINE: Connection opened for gpt, jndiName: jdbc/gpt, productName: PostgreSQL, driver: PostgreSQL Native Driver PostgreSQL 9.1 JDBC4 (build 901)
Jul 22, 2014 1:17:07 PM com.esri.gpt.control.georss.RestQueryServlet execute
SEVERE: Error executing query.
com.esri.gpt.catalog.search.SearchException: Error while getting items from repository with id of nsidcCould not get record from db with rid = nsidc
at com.esri.gpt.catalog.search.SearchEngineExternalCsw.init(Unknown Source)
at com.esri.gpt.catalog.search.SearchEngineFactory.intializeEngine(Unknown Source)
at com.esri.gpt.catalog.search.SearchEngineFactory.createSearchEngine(Unknown Source)
at com.esri.gpt.control.georss.RestQueryServlet.executeQuery1(Unknown Source)
at com.esri.gpt.control.georss.RestQueryServlet.execute(Unknown Source)
at com.esri.gpt.framework.context.BaseServlet.doPost(Unknown Source)
at com.esri.gpt.framework.context.BaseServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:701)
Caused by: com.esri.gpt.catalog.search.SearchException: Could not get record from db with rid = nsidc
at com.esri.gpt.catalog.search.GptRepository.readHarvestRecord(Unknown Source)
... 23 more
Jul 22, 2014 1:17:07 PM com.esri.gpt.framework.sql.DatabaseReference closeConnection
FINE: Closing connection for gpt, jndiName: jdbc/gpt
There are no other errors reported by either GPT or Tomcat. Any help would be appreciated.
