I need a script to check the attribute indexes of every feature class in a geodatabase, to delete or create the indexes to fit my needs.I've used the ListIndexes arcpy function but it lists not only attribute indexes but also spatial indexes. Is there a way to list only attribute indexes?import arcpy
fields = "OBJECTID"
index_name = "FDO_OBJECTID"
unique_vals = "UNIQUE"
order = "ASCENDING"
FSO_OID = False
try:
gdb = arcpy.GetParameterAsText(0)
arcpy.env.workspace = gdb
fdatasets = arcpy.ListDatasets()
for fdataset in fdatasets:
arcpy.AddMessage("Feature dataset: " + fdataset)
arcpy.AddMessage('-' * 40)
fcs = arcpy.ListFeatureClasses('','',fdataset)
for fc in fcs:
indexes = arcpy.ListIndexes(fc) # ----> Lists both attribute and spatial indexes!!!
for index in indexes:
if (index.name <> index_name):
arcpy.RemoveIndex_management(fc, index.name)
else:
FSO_OID = True
if FSO_OID == False:
arcpy.AddIndex_management(fc, fields, index_name, unique_vals, order)
except:
arcpy.GetMessages(2)
