I am newby for ARCGis SDK for Qt, and I have issue in loading this URL of FAA Visual Chart Viewer: https://faa.maps.arcgis.com/apps/webappviewer/index.html?id=7d74890ce98d47b5b2bf4dd96b7c6ce5. I am using the "Display a web map" tutorial (https://faa.maps.arcgis.com/apps/webappviewer/index.html?id=7d74890ce98d47b5b2bf4dd96b7c6ce5) and replacing the url with "https://faa.maps.arcgis.com/apps/webappviewer/index.html?id=" and item_id with "7d74890ce98d47b5b2bf4dd96b7c6ce5", but executing the app, the blank screen keeps showing. I have set my API key.
Anybody has any clue?
Thank you in advance
Regards
Hello Massimiliano,
Try using this URL instead: https://faa.maps.arcgis.com/home/item.html?id=2582e07533e74113a07d1b6d410442af
Like Gintautas said, the id/url you provided is for a Web Mapping Application, whereas the one I just listed is for a Web Map.
"7d74890ce98d47b5b2bf4dd96b7c6ce5" is Web Mapping Application ID. You need Web Map ID.
Thank you very Gintautas and bnoble0110. With the ID you provided, it works.
You should also check the Map LoadStatus and LoadError properties - the error message should have included information that the portal item type was incorrect. List of All Members for Map | ArcGIS Maps SDK for Qt | ArcGIS Developers
Just a curiosity, where did you find this ID 2582e07533e74113a07d1b6d410442af?
