"TypeError: Cannot read properties of null (reading 'attr')" - Is anyone else getting this new error on existing surveys? Seems connected to "dropdown" type questions... Deleting the existing question and re-adding it fixes the issue, but that doesn't help existing surveys.
A fix to this issue has been deployed. @Tim_Ultee @KevinMcMaster2 @LindaLin1 @cbolen: your survey should now continue working without further action from your side.
@IsmaelChivite @JamesTedrick - thank you!
We are aware of this issue and looking into it.
Seconding this issue as I've got an existing survey out that is not capturing responses. This behavior appeared simultaneously with this error.
Following. Experiencing the same thing on an existing Survey.
My existing survey having the same error occurred from yesterday, form worked in field map but not in web browser. same error message as above. the form was working completely fine previously.
Please help to fix the issue as soon as possible.
Many thanks
Having the same issue with one of our surveys as well, yet not another similar survey. Hoping this is fixed or the solution is identified quickly.
Thank you, it appears to be back to normal!
Confirmed, thanks Ismael.
Yes! Nearly a dozen public and internal surveys were impacted yesterday. Huge inconvenience and our client is looking to for answers and remedy ASAP.
Thank you @IsmaelChivite , @JamesTedrick , and the S123 team for their lightning-quick fix to this problem as soon as it was identified!
