I have a Python script I created after my ModelBuilder model got too clunky and slow, but I'm stuck. I have a point shapefile that I want to buffer then run Zonal Statistics on that buffered point. Following that, I need to run raster calculator, int, and raster to polygon geoprocessing tools so the value output by the Zonal Statistics tool can be copied to another shapefile. There is also another attribute that needs to persist throughout.
I've been having trouble with SearchCursor; it isn't iterating. It uses all the features in the input shapefile rather than the one it's on. So, I decided to try selecting the row it's on and exporting to a new shapefile, but I don't know how to include row[] in the SQL expression (I know the one in the code is incorrect).
I'd appreciate any help--please be kind, though! I'm learning!
I've also included a screen shot of my model that works in ModelBuilder, in case that helps.
import sys
import arcpy
from arcpy.sa import *
import math
import os
arcpy.env.overwriteOutput = False
# Check out any necessary licenses.
arcpy.CheckOutExtension("spatial")
arcpy.CheckOutExtension("ImageAnalyst")
arcpy.CheckOutExtension("3D")
# Model Environment settings
Depression_NHD_Intersect_Layer = "D:\\Projects\\TESTING_Depression_NHD_Intersect.shp"
AOI_Raster = "D:\\Projects\\0710000404_DeerCreekDesMoinesRiver.tif"
HUC10_RSTFile_Path = "D:\\Projects\\RSTFiles\\"
HUC10_SHPFile_Path = "D:\\Projects\\SHPFiles\\"
Point_Buffer_Output = HUC10_SHPFile_Path + "Buffer.shp"
fields = ['FID', 'DepressFID']
#Create Empty Feature Class
FP_Intersections_Elev = arcpy.management.CreateFeatureclass(HUC10_SHPFile_Path, "FP_Intersections_Elev_TEST.shp", "POLYGON", "D:\\Projects\\FP_Intersections_Elev_TEMPLATE.shp", "DISABLED", "DISABLED", "D:\\Projects\\FP_Intersections_Elev_TEMPLATE.shp")
#Buffer
arcpy.Buffer_analysis(Depression_NHD_Intersect_Layer, Point_Buffer_Output, "3 Meters", "" , "" , "NONE", "" , "PLANAR")
with arcpy.da.SearchCursor(Point_Buffer_Output, fields) as cursor:
for row in cursor:
Make_Feature_Layer = HUC10_SHPFile_Path + str(row[1]) + '.shp'
Single_Buffer_Layer = HUC10_SHPFile_Path + "DepressFID_" + str(row[1]) + '.shp'
Zonal_Stats_Output = HUC10_RSTFile_Path + "ZoneStats_" + str(row[1]) + '.tif'
Raster_Calc_Output = HUC10_RSTFile_Path + "RasterCalc_" + str(row[1]) + '.tif'
Int_Output = HUC10_RSTFile_Path + "Int_" + str(row[1]) + '.tif'
Raster_to_Poly_Output = HUC10_SHPFile_Path + "NHD_Poly_" + str(row[1]) + '.shp'
sql = '"FID" = \'(row[0])\''
#Make Feature Layer
arcpy.Select_analysis(Point_Buffer_Output, Single_Buffer_Layer, sql)
#Zonal Statistics
outZonalStats = ZonalStatistics(Single_Buffer_Layer, "DepressFID", AOI_Raster, "MEAN")
outZonalStats.save(Zonal_Stats_Output)
#Raster Calculator to prepare to change value to integer
outRasCal = RasterCalculator([Zonal_Stats_Output], ["x"], "x*1000000")
outRasCal.save(Raster_Calc_Output)
#Int (integer) Raster
outInt = Int(Raster_Calc_Output)
outInt.save(Int_Output)
#Raster to Polygon
arcpy.conversion.RasterToPolygon(Int_Output, Raster_to_Poly_Output, "NO_SIMPLIFY", "VALUE")
#Add Fields to Polygon Layer
arcpy.management.AddField(Raster_to_Poly_Output, "DepressFID", "LONG")
arcpy.management.AddField(Raster_to_Poly_Output, "gridfloat", "FLOAT")
arcpy.management.AddField(Raster_to_Poly_Output, "elevft", "FLOAT")
#Calculate New Fields
arcpy.management.CalculateField(Raster_to_Poly_Output, "DepressFID", row[1])
arcpy.management.CalculateField(Raster_to_Poly_Output, "gridfloat", "!gridcode!/1000000", "PYTHON3")
arcpy.management.CalculateField(Raster_to_Poly_Output, "elevft", "!gridfloat!*3.2808", "PYTHON3")
#Append shapefile to FP_Intersections_Elev shapefile
arcpy.management.Append(Raster_to_Poly_Output, FP_Intersections_Elev, "TEST", "" , "" , "" , "" , "NOT_UPDATE_GEOMETRY")
#Delete Intermediate Files
arcpy.management.Delete(Zonal_Stats_Output)
arcpy.management.Delete(Raster_Calc_Output)
arcpy.management.Delete(Int_Output)
arcpy.management.Delete(Raster_to_Poly_Output)
print("Completed DepressFID: " + str(row[1]))
print("All DepressFIDs Completed!")
