I've been making changes to my web map popups. I'm not seeing these changes reflected in the web map inside Experience Builder. I set the autor-efresh, but I'm still not seeing changes in the fields. I'm new to EB so maybe I'm missing something?
new to experience builder, added a layer to webmap that used by experience, not seeing the change.
anything I can change in arcgisAssistant to make the update going through?
If I can chime in 2 years later, I find that re-adding the republished map layer to the web map shows the changes made to the popup (I make the changes in APro). But it breaks any query or search widgets you may have created in an Exp Build. app for for that layer. Then you have to redo all of those queries. Very annoying. Can't find a good solution. Saving the web map as a copy would break the entire Ex Build app, not just for that layer. Very annoying.
Have you tried to make copy of updated published web map and use copy instead?
Yes, I just tried that and the visible fields haven't changed in the layer.
Have you tried doing a hard refresh (Ctrl-F5) of the browser window to clear the cache and force it to read the map in again?
Levi, this is a bit clunky. I found that I sometimes have to remove my web map and add it again when I make "big" changes like this. But that's just my experience. Once I add it again, things act normal.
