I've recently done some hotspot analysis and i used the maximum distance for each point to have at least one neighbour as the deyermining factor because a large number of points don't have a neighbour, they are discounted from the hotspot analysis.I would suggest viewing the spatial statistics video here for more info:http://training.esri.com/acb2000/showdetl.cfm?DID=6&Product_ID=1002Cheers
Hi Franky, I'm glad to hear you've found the resources and are looking at the peak z-score distances to choose a distance band for hot spot analysis. Hopefully you're using the Incremental Spatial Autocorrelation tool to do this, which you can find in our Supplementary Spatial Statistics toolbox. This is a great question that you bring up, and its especially common, for instance, when you have a lot of features with similar sizes (small polygons in the more urban areas), and then a couple of features that are much larger (big polygons in more rural/suburban areas). A good option for dealing with this is to create a Spatial Weights Matrix. From the Generate Spatial Weights Matrix tool, you can set the Distance Band to the distance at which the z-score peaks, and then use the Number of Neighbors parameter to make sure that for those features that don't have any neighbors at the distance that you chose, they'll have at least the number of neighbors that you set. So, for example, if you choose a distance of 500m, and there are a couple of features that don't have any neighbors at 500m, but you also set a Number of Neighbors at 2...then for those features WITHOUT any neighbors at the specified distance band we'll increase the threshold to ensure those particular features have at least 2 neighbors. You can only do it using the Generate Spatial Weights Matrix option, and then from Hot Spot Analysis you'll choose to Get Spatial Weights From File. We often use this option when dealing with this issue. Hope this helps! Lauren RosensheinGeoprocessing Product EngineerCheck out the latest Spatial Statistics resources at http://esriurl.com/spatialstats
