I encountered an issue regarding creating a relationship feature class in a test sde database. The issue that I encountered is the script will create the relationship class, but for some reason none of the data relates for some reason. At first, I thought it might be due to none of the related features having data in them as a possibility. I ran the same script with data in both of the features and it worked. I don't know why this would be an issue or if anyone else has had similar issues, but I would like to know if there is a way to make certain that this won't happen again next time the script runs.
# Import arcpy da modules
from arcpy.da import (
# Import functions/classes pertaining to editing features in databases
Editor as Editing, SearchCursor as Searching, InsertCursor as Inserting, UpdateCursor as Updating,
# Import functions/classes pertaining to looping or creating item lists
ListDomains, Walk, ListVersions, ListContingentValues
# Import arcpy management modules
from arcpy.management import (
# Creating features
CreateFeatureDataset as MakeDataset, CreateFeatureclass, CreateTable ,
# Feature field modifications
AddField, AlterField as ModifyField , DeleteField ,
# Creating, deleting, or modifying domains
CreateDomain, AlterDomain, AddCodedValueToDomain as AddCode, DeleteCodedValueFromDomain as DeleteCode, SetValueForRangeDomain as SetRange, DeleteDomain, AssignDomainToField, RemoveDomainFromField ,
# Attribute rules
EnableAttributeRules, DisableAttributeRules, AddAttributeRule, AlterAttributeRule, DeleteAttributeRule ,
# Creating feature relations
CreateRelationshipClass as MakeRelation, AddRelate, RemoveRelate ,
# Establishing roles and users
CreateRole, ChangePrivileges, CreateDatabaseUser, ChangePrivileges, UpdatePortalDatasetOwner ,
# Updating licensing information
UpdateEnterpriseGeodatabaseLicense as LicenseUpdate ,
# Enabling or disabeling editor tracking on features
EnableEditorTracking as TrackEdits, DisableEditorTracking as StopTrackEdits ,
# Managing versions
CreateVersion, ChangeVersion, AlterVersion, DeleteVersion , RegisterAsVersioned , UnregisterAsVersioned ,
# Creating contingent values
CreateFieldGroup , AlterFieldGroup , DeleteFieldGroup , AddContingentValue , RemoveContingentValue ,
# Add global ids
AddGlobalIDs ,
# Create database connections
CreateDatabaseConnection ,
# Manage layer symbology from existing layer
ApplySymbologyFromLayer ,
# Make a feature layer
MakeFeatureLayer , SaveToLayerFile
# Create relationship table between certain feature classes
def RelateFeatures( InputDatabase, RelateFeaturesDictionary ):
Tab = ' ' * 4
print ( f'Creating relationship classes for relations in { list( RelateFeaturesDictionary ) }' )
# Important variables
Relationships = 'Relationships'
Origin, Destination, ToLabel, FromLabel, Field = 'Origin', 'Destination', 'ToLabel', 'FromLabel', 'Field'
To, From, Both, Neither = 'FORWARD', 'BACKWARD', 'BOTH', 'NONE'
Attributed, NotAttributed = 'ATTRIBUTED', 'NONE'
Simple, Composite = 'SIMPLE', 'COMPOSITE'
OneCardinality, OneManyCardinality, ManyCardinality = 'ONE_TO_ONE', 'ONE_TO_MANY', 'MANY_TO_MANY'
# Important feature classes and tables
FeatureClasses = { filename : Combine( InputDatabase, filename ) for root, directory, filenames in Walk( InputDatabase, datatype='FeatureClass' ) for filename in filenames }
Tables = { filename : Combine( InputDatabase, filename ) for root, directory, filenames in Walk( InputDatabase, datatype='Table' ) for filename in filenames }
# Get all relationship feature classes
Relationships = { filename : Combine( InputDatabase, filename ) for root, directory, filenames in Walk(InputDatabase, datatype='RelationshipClass') for filename in filenames }
ValidateExistingRelationships = [ RelateName for RelateName in RelateFeaturesDictionary for ExistingRelation in Relationships if RelateName in ExistingRelation ]
# Create the relationships for each named relation in the dictionary
for Relation in RelateFeaturesDictionary:
OriginName = RelateFeaturesDictionary[ Relation ][ Origin ]
DestinationName = RelateFeaturesDictionary[ Relation ][ Destination ]
RelationshipClass = Combine( InputDatabase, Relation )
OriginFeature = None
DestinationFeature = None
OriginLabel = RelateFeaturesDictionary[ Relation ][ ToLabel ]
DestinationLabel = RelateFeaturesDictionary[ Relation ][ FromLabel ]
KeyField = RelateFeaturesDictionary[ Relation ][ Field ]
# Get the origin feature from either feature classes or tables
for Name in FeatureClasses:
Fullname = None
if '.' in Name:
Fullname = Name.split( '.' )[ -1 ]
if Fullname == OriginName:
OriginFeature = FeatureClasses[ Name ]
# Get the destination feature from either feature classes or tables
for Name in Tables:
Fullname = None
if '.' in Name:
if Fullname == DestinationName:
DestinationFeature = Tables[ Name ]
# Create the relationship class if the relationship class does not exist
if Relation not in ValidateExistingRelationships:
NewRelation = MakeRelation( OriginFeature, DestinationFeature, RelationshipClass, Simple, OriginLabel, DestinationLabel, To, OneManyCardinality, NotAttributed, KeyField, KeyField )
print ( f'{ Tab }{ NewRelation } has been created between { RootName( OriginFeature ) } as the origin and { RootName( DestinationFeature ) } as the destination' )
print ( '\n' )
return
# Core relationship features
Relationships = {
'Relationship Name' : {
Origin : FeatureA,
Destination : TableA,
ToLabel : 'To Message',
FromLabel : 'From Message',
Field : 'Selected Field Name'
# Create relationships
RelateFeatures( MainDatabase, Relationships )
