Hello! We are using the Hub data portal to serve out public datasets that use coded domains as attribute values. Is there a way in the Hub Data Explore Page (https://oregon-department-of-forestry-geo.hub.arcgis.com/datasets/geo::hydrography-flow-line/explore) to have the coded domain descriptions show up when a user uses identify on a record? Currently they are only showing the domain code.
Thanks!
-arthur
I have the same issue with my data and I dont know the way around it aside from reformatting my data to have domain codes that are the same as the description. I want users to be able to filter the data using the descriptions, but it presents the codes only. This is supported in other esri spaces with the notable exception being the space designed accommodate data downloading. If it is in there and I am missing something, it is not apparent.
