As we work to clean up legacy issues in our Fabric, sometimes we're redrawing curves or using SLACA, but this leaves behind the old densified points. Back in the before times there was a tool to deal with orphaned points but currently that doesn't exist in Pro.
So, I'm here for another sanity check. If I select all the points then use the Select By Location tool to remove from the selection points that intersect any of the <Fabric_Parcel_Type>_Lines (including historic) and the Connection Lines, at the end all I should be left with is orphaned points selected.
So, I do that and I end up with about 2500 out of 150k points selected as orphaned. For now I'm just going to flag them so I can inspect them, but does this workflow seem correct?
