I have a DEM raster for Germany with about 2000 pixels. A "value" that describes the altitude below or above the sea level is attached to each individual pixel in the attribute table that I gained access to when I converted the raster from float to integer using the Int-tool.
I would like to convert the raster to polygons, but by converting every raster pixel to a polygon so that the number of polygons matches the amount of raster pixels.
Background: I would like to use joins later, to add the "values" from the raster to each polygon that has been created.
What is the right way to do that probably? Whenever I use "Raster to polygon" and/or "Reclassify", I obtain way more polygons then raster pixels, mostly about 55000. When I use the created polygon-file, I cannot copy the "values" from one attribute table to another.
Thank you in advance,
Tobias
