Is it possible to use Calcite components or icons inside ArcGIS Site/Hub ?
Hello @MathieuVillemont,You are correct. It is not in ArcGIS Enterprise Sites yet. It will be available in the Text Card in 11.2.
Hello @MathieuVillemont,You can use select any of the calcite components, including the calcite icons, in Hub via our Text Card. You just have to switch to Edit in HTML first and then you can paste in the component code.Edit 02/26/24: It turns out I was incorrect when I stated that any of the calcite components could be used. For a list of supported components see: https://doc.arcgis.com/en/hub/sites/add-text-and-images.htm#ESRI_SECTION1_3E6FBF82D17C476D9A7AA6F432E38CAA in Hub documentation or https://enterprise.arcgis.com/en/sites/latest/sites/add-text-and-images.htm#ESRI_SECTION1_3E6FBF82D17C476D9A7AA6F432E38CAA in Enterprise Sites documentation.
Thanks @KlaraSchmitt.
It works well in Hub, however not in Site. I'm having Portal 10.8.1. Maybe a newer version would fix that ?
Works great in 11.2
