Curious when the draw tool in ExB through enterprise will be available? I thought it was suppose to be released with Enterprise 11.0, but I'm not seeing it unless I'm not looking in the correct area.T.I.A
@DanaYoung
The URL had an extra comma added by accident, and I just removed & updated it.
Yeah, I would suggest going to Tech Support. There might be something incorrect when deploying the Enterprise or its API dependence.
Also that first link you listed, said the page was not found... https://developers.arcgis.com/experience-builder/guide/1.8/whats-new/
Humm seems I may need to contact Support, because despite I am on version 11, I do not have access to this. Within my "Insert" pane I have "Basic", "Layout", and "Section" I don't see a "Map Centric" location. Also when I search for "draw" nothing populates. Also when I choose "select" from the Map options pane, it has a bar on top of the tool moving along as though it's trying to load but I can't use it. I can't select the drop down. So not sure what's happening here. I have provided screen shots that shows I am on v 11, as well as what my ExB pane looks like for "Insert" and when I try to search for "draw". If you look at the "Select" snap shot I circled the bar that is moving across the top and you can see that it's all greyed out.
The Draw widget was first added in dev1.8 - https://developers.arcgis.com/experience-builder/guide/1.8/whats-new/
You can refer to the release versions here:
https://developers.arcgis.com/experience-builder/guide/release-versions/
So the widget should be included in Enterprise v11.0.
I checked a v11.0 portal, the widget is there:
You can use the search tool as well
I mean widget not tool....
