public class _bufferItems { public string Name { get; set; } public string Address { get; set; } public string City { get; set; } public string State { get; set; } public string Zip { get; set; } }
// "_bufferList" will hold all if the results from the parcel query and display them in the child window when called _bufferList = new List<_bufferItems>();
<!-- This is the Line thats visible between the Identify Results list and the Tab Control--> <Line X1="178" X2="178" Y1="0" Y2="365" Stroke="Black" StrokeThickness="1" Grid.ColumnSpan="2" />
private void QueryTask_ExecuteCompleted(object sender, QueryEventArgs args) { //Reset Selected (blue) graphics identifySelect.ClearGraphics(); //Add all blue (Selected) graphics to graphics layer foreach (DataItem x in _bufferSelectedItems) { ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic() { Geometry = x.geodata, Symbol = GlobalVariables.theMainPage.LayoutRoot.Resources["SelectedFillSymbol"] as FillSymbol }; identifySelect.Graphics.Add(graphic); } //Reset Results (red) graphics identifyResults.ClearGraphics(); // "_bufferList" will hold all if the results from the parcel query and display them in the child window when called _bufferList = new List<_bufferItems>(); //Add all red (Results) graphics to graphics layer //And add each result to the buffer csv list foreach (Graphic feature in args.FeatureSet) { string StreetNum = ""; string StreetDir = ""; string Street = ""; string StreetType = ""; feature.Symbol = GlobalVariables.theMainPage.LayoutRoot.Resources["ResultFillSymbol"] as FillSymbol; bool uniqueGraphic = true; //If graphic exists in Selection Graphics Layer (_bufferSelectedItems), do not add to Results Graphics Layer //This allows the user to see the initial buffer selection versus the parcels returned from the buffer parcel query foreach (DataItem x in _bufferSelectedItems) { if (x.Data[StringID.APN].ToString() == feature.Attributes[StringID.APN].ToString()) { uniqueGraphic = false; } } if (uniqueGraphic) { identifyResults.Graphics.Add(feature); } //Create a new buffer item _bufferItems rptItemsSitus = new _bufferItems(); _bufferItems rptItemsOwner = new _bufferItems(); //Gather individual fields to create full address //This "if" statement returns true if the user is looking for situs or both addresses if (GlobalVariables.theBufferChoice.rdoBoth.IsChecked == true || GlobalVariables.theBufferChoice.rdoSitus.IsChecked == true) { if (feature.Attributes[StringID.csvStNum] != null) { StreetNum = feature.Attributes[StringID.csvStNum].ToString().Trim(); } if (feature.Attributes[StringID.csvStDir] != null) { StreetDir = feature.Attributes[StringID.csvStDir].ToString().Trim(); } if (feature.Attributes[StringID.csvSt] != null) { Street = feature.Attributes[StringID.csvSt].ToString().Trim(); } if (feature.Attributes[StringID.csvStType] != null) { StreetType = feature.Attributes[StringID.csvStType].ToString().Trim(); } //Use "Occupant" for external users rptItemsSitus.Name = "Occupant"; //Concatinate address rptItemsSitus.Address = StreetNum + " " + StreetDir + " " + Street + " " + StreetType; if (feature.Attributes[StringID.csvCity] != null) { rptItemsSitus.City = feature.Attributes[StringID.csvCity].ToString(); } if (feature.Attributes[StringID.csvState] != null) { rptItemsSitus.State = feature.Attributes[StringID.csvState].ToString(); } if (feature.Attributes[StringID.csvZip] != null) { rptItemsSitus.Zip = feature.Attributes[StringID.csvZip].ToString(); } _bufferList.Add(rptItemsSitus); } //This "if" statement returns true if the user is looking for owner or both addresses if (GlobalVariables.theBufferChoice.rdoBoth.IsChecked == true || GlobalVariables.theBufferChoice.rdoOwner.IsChecked == true) { if (feature.Attributes[StringID.csvMailAddress] != null) { Street = feature.Attributes[StringID.csvMailAddress].ToString().Trim(); } if (feature.Attributes[StringID.csvFirstLast] != null) { rptItemsOwner.Name = feature.Attributes[StringID.csvFirstLast].ToString().Trim(); } //Concatinate address rptItemsOwner.Address = Street; if (feature.Attributes[StringID.csvMailCity] != null) { rptItemsOwner.City = feature.Attributes[StringID.csvMailCity].ToString(); } if (feature.Attributes[StringID.csvMailState] != null) { rptItemsOwner.State = feature.Attributes[StringID.csvMailState].ToString(); } if (feature.Attributes[StringID.csvMailZip] != null) { rptItemsOwner.Zip = feature.Attributes[StringID.csvMailZip].ToString(); } _bufferList.Add(rptItemsOwner); } } //Fill datagrid with results dgReport.ItemsSource = _bufferList; //lets the BufferChoice control know that the report has run GlobalVariables.theSideMenu.buffercontrol.makeChoiceOpenFalse(); }
private void SaveButton_Click(object sender, RoutedEventArgs e) { SaveFileDialog sfd = new SaveFileDialog() { DefaultExt = "csv", Filter = "Comma Separated Values (*.csv)|", FilterIndex = 1 }; int bufferCount = _bufferList.Count; sfd.ShowDialog(); System.IO.Stream stream = sfd.OpenFile(); StreamWriter sw = new StreamWriter(stream); sw.Write("\"Name\",\"Address\",\"City\",\"State\",\"Zip\""); for (int i = 0; i <= bufferCount - 1; i++) { sw.Write("\"" + _bufferList.Name + "\",\"" + _bufferList.Address + "\",\"" + _bufferList.City + "\",\"" + _bufferList.State + "\",\"" + _bufferList.Zip + "\" "); } sw.Close(); stream.Close(); }
If featureSet IsNot Nothing AndAlso featureSet.Features.Count > 0 Then For Each feature As Graphic In featureSet.Features feature.Symbol = TryCast(LayoutRoot.Resources("ResultsFillSymbol"), FillSymbol) graphicsLayer.Graphics.Insert(0, feature) Next feature ResultsDisplay.Visibility = Visibility.Visible End If
'Dim listClass As IList(Of [MyClass]) = DirectCast(QueryDetailsDataGrid.SelectedItems, IList(Of [MyClass]))
IList<MyClass> listClass = (IList<MyClass>)myDataGrid.SelectedItems;
