Hello, I would like to know what 3D object extensions the map supports besides glTF and glb, since I have a 3D object with an nwd extension and I would like to know if it is possible to place it on the map.
As resource for Object3DSymbolLayer, gltf/glb is the only supported 3D file format. See: https://developers.arcgis.com/javascript/latest/api-reference/esri-symbols-ObjectSymbol3DLayer.html#resourceDepending on use case and size/complexity of the 3D object, the other option is to use ArcGIS Pro to create a SceneLayer from the 3D object for loading in a map. However, .nwd is not supported in Pro either, so would need to be converted, or exported to a different format first (e.g. IFC, Revit). See also: https://gis.stackexchange.com/questions/358591/importing-a-max-or-nwd-files-into-arcgis-pro#:~:text=ArcGIS%20Pro%20will%20not%20support,open%20directly%20in%20ArcGIS%20Pro.
