Hello everyone. I am using ArcGIS Pro 3.1.2. I am trying to share a web map, I made a copy of the map I use primarily to test out sharing a web map. We use NAD 1983 in our primary map, but when I attempted to share the copied map to the web, I received errors, needing to select a basemap, than I had to keep the same projection throughout the map, ultimately matching my basemap, WGS 1984.
Pictured, is the primary map in NAD and the copy in WGS. When I make edits or move points in my map, they also move in the copy. Another thing is, in my primary, the points are tight and uniform, as I have spent a lot of time making points uniform. In the other map, the points do not appear that way, and when I attempt to adjust them in the copy, it also moves the points in my primary, appearing not uniform. How can I maintain that uniform look, while also making the necessary adjustments to the projection? Is there any way to share as NAD with a NAD basemap? Or a way to go to WGS without such a big difference in position? I think the changes are reflected in both places because the layers share the geodatabase, would I be better off making an entirely different map with shapefiles or something instead of sharing geodatabase? Help pls, thanks!
