Is it possible to have a watermark added when a .jpeg is submitted through a File question?
Well bummer looks like it was never added for exsisting images. This is in the post I linked to above https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-photo-watermarks/ba-p/893593
Yes this post has all the info https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-photo-watermarks/ba-p/893593
But note if the crew makes a mistake it is there forever. Hope that helps
Hi Doug,
Thanks for the reply. It seems this only works when Type is set to image. I need the watermark to be applied to a pre-existing image file that the users is selecting manually. See below.
You can use image and browse to a file if you add this setting (this is new it used to do both). You can have both options or force the user one way or the other.
In the column body::esri:style set it to method=camera,browse and see if that does it.
Hi Doug, thanks for the info. I have tried using your suggestion, however it still does not work and no watermark is applied. Any further suggestions?
