Ik probeer numerieke of tabelwaarden op te halen op basis van hoogteprofielen in Drone2Map, maar ik ben er niet in geslaagd om uit te vinden hoe (de knop "Export as table" is grijs weergegeven). Heeft iemand suggesties?
Great, thank you both. I'll see if my university has an ArcGIS Pro license and give it a shot.
Thanks to Jeff for offering the suggestion to do this analysis in ArcGIS Pro. For Melody, I've confirmed with the development team that there is a software licensing limitation that prevents us from exposing the export capability, so that menu will be removed in the next release. Moving to Pro is the recommended workflow.
ThanksCody B.
If you are unable to use "export as table" in Drone2Map, you can open your results in ArcGIS Pro using the Open in ArcGIS Pro button on the top ribbon in Drone2Map. Once in Pro, you can use the Elevation Profile tool in the Exploratory 3D Analysis drop-down menu in the Workflows group on the Analysis tab. You can then export your results to a CSV. More info on the ArcGIS Pro tool here: https://pro.arcgis.com/en/pro-app/latest/help/mapping/exploratory-analysis/interactive-elevation-profile-basics.htm
