Goedemorgen. Ik werk me door verschillende elementaire tutorials heen... nu in ArcGIS Online Basics. Moet ik oefeningen doen met ArcMap of (aangezien ArcMap binnenkort wordt vervangen door ArcGIS Pro ??) moet ik nu verder gaan met ArcGIS Pro?</P>
@MHoagland the responses above are correct, you should learn ArcGIS Pro, not ArcMap. Here are some tutoriaIs that I recommend:
Thank you for the reply. I had trouble getting ArcGIS Pro installed. I got great help from Affi at ESRI. I am now ready to start tackling the tutorials that you suggested.
Thanks again.
You are welcome!
All set with starting ArcGIS Pro. Thanks.
@MHoagland have you already installed ArcGIS Pro? If not, find the .exe file you downloaded and follow the prompts to install the program. You can find more detailed instructions here: Install ArcGIS Pro.
Once it is installed, click your computer's Start button and type ArcGIS Pro to find the application.
OK... really dumb question. I'm trying the "Get Started with GIS Pro" tutorial. I'm stuck at the very first step which is... "start ArcGIS Pro." I'm looking everywhere for how to do start ArcGIS Pro and I keep finding myself at the pages where I'm supposed to buy or try it. But I already did...as an individual.
Some addtional resources. If you are looking for Mapping and Visualization:
Maps for Office: Enhancing your PowerPoint slides with ArcGIS -BLOG
Great! Thank you all!
Good morning, MHoagland,
I would definitely suggest ArcPro.
Good morning MHoagland,
Yes, ArcGIS Pro is the better choice since ArcMap will soon be deprecated.
Best of luck!
