There seems to be quite a bit of functionality that has not or will not be replicated in experience builder. Here are some widgets I’m having problems reproducing their functionality in experience builder:
The Select widget has been added along with the latest AGOL release. Let us know if you encounter any other issues, thanks.
Tonghui
I found in another post that improvements to the standalone select widget is on track for Q1 of 2024. Seeing that Portal 11.2 is out and doesn't have it, will there be another release in the next month?
Thank you! This is definitely an improvement, but it's still lacking the functionality that web app builder provides. I cannot seem to find a way to select one or multiple records in the table and zoom/export those features. These options are available when you set up individual "sheets", but then those sheets are not linked to the map layers widget.
By the way, is there a way to collapse/minimize the table to the bottom of the map view, as it was configured in web app builder? I have multiple widgets setup in a vertical sidebar, but it appears that you cannot setup a second horizontal sidebar to hold the table.
Hi @shildebrand
For your first question, it has been supported in the Map Layers widget:
https://doc.arcgis.com/en/experience-builder/latest/get-started/whats-new.htm
Try finding it in the View in Table data action configured in the Map Layers widget. One or more tables can be configured and you can add all layers in them:
As for No.2 & 3 about the select behavior, the Map widget select tool provides basic & simple selection choices. More advanced functions are under evaluation.
For the Draw widget text symbols, we are currently communicating with the corresponding parties, who will evaluate the potential enhancement possibilities.
Thanks for bringing these up.
