Hello ArcGIS Monitor Team,
Please add the ability to filter and sort by Label. Currently this functionality is not in the 2023.2
Not listed in filter:
Not listed in Sort:
Not listed on the field:
Thanks for your consideration,
Amanda Huber
Hi @Amanda__Huber,FYI: Please select the label(s) you would like to "sort" or "filter" on - by selecting the desired label(s) under the "Labels" button (which is located to the left of the "Sort" button in the UI. Then apply the desired "sort" or "filter". I think this is what you're asking for. If not, can you please clarify what you would like to do?Hope this helps,
@DerekLaw
Thanks for the quick reply! Ah that makes sense, totally missed that option (not the first place I would have intuitively looked). Thank you!
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
