I have perhaps an unusual request. So bear with me.
I am attempting to write a Python 3 script that will list all domain names from my enterprise geodatabase that start with the letter "e", as well as their domain type, code/min, and description/max, and have them saved in a log file (.csv and .xlsx). At the same time, I also want to capture in another log file the history of only those domains that were altered (e.g., deleted, added, changed, etc.) and when it happened.
Here is my three-part question:
1. Does ESRI system tables (SQL Server 2019) keep track of when domain changes happen and what those changes were?
2. Can a Python 3 script retrieve that info from system tables?
3. Is there another way to go about this?
The following code doesn't really give me what I need. Instead, it gives me a list of all the domains that start with "e" yet it adds the date of when I ran the script and not the date when I actually altered the domain. Plus, it doesn't add the header "Date_Modified_2" inside my log file.
See attached log file (.csv).
I want it to write:
DOMAIN_NAME,DATE_MODIFIED,DATE_MODIFIED_2
eGuyType,2023-06-27 13:30:08.858138
eDeviceMounting,2023-06-27 13:30:08.858138,2023-06-29 15:20:00.590812
ePhase,2023-06-27 13:30:08.858138,2023-06-29 15:20:00.590812
eSecConductorType,2023-06-27 13:30:08.858138
eSwitchState,2023-06-27 13:30:08.858138,2023-06-29 15:20:00.590812
eImpedanceUnits,2023-06-27 13:30:08.859136,2023-06-29 15:20:00.590812
eConnectionTypeWyeDelta,2023-06-27 13:30:08.859136,2023-06-29 15:20:00.590812
eSecondaryType,2023-06-27 13:30:08.859136,2023-06-29 15:20:00.590812
ePrimaryType,2023-06-27 13:30:08.859136,2023-06-29 15:20:00.590812
eMountType,2023-06-27 13:30:08.859136
Thanks.
import arcpy
import csv
from openpyxl import Workbook
from openpyxl.styles import Font
import datetime
gdb = r"E:\SDE\OWNER_PROD.sde"
xlsx_filepath = r"E:\ScriptLogs\ExportDomains.xlsx"
csv_filepath = r"E:\ScriptLogs\ExportDomains.csv"
modification_table_csv = r"E:\ScriptLogs\LPDomainHistory.csv"
modification_table_xlsx = r"E:\ScriptLogs\LPDomainHistory.xlsx"
domains = arcpy.da.ListDomains(gdb)
wb = Workbook()
ws = wb.active
# Write the header for domain list in Excel file
header_xlsx = ["DOMAIN_NAME", "DOMAIN_TYPE", "CODE/MIN", "DESCRIPTION/MAX"]
ws.append(header_xlsx)
header_font = Font(bold=True)
for cell in ws[1]:
cell.font = header_font
# Write the header for the CSV file
header_csv = ["DOMAIN_NAME", "DATE_MODIFIED"]
# Read existing modification dates from the CSV file
modification_dates = {}
if arcpy.Exists(modification_table_csv):
with open(modification_table_csv, 'r') as csv_file:
reader = csv.reader(csv_file)
headers = next(reader) # Get the headers
for row in reader:
domain_name = row[0]
modification_dates[domain_name] = row[1:]
# Capture domain modification information
for domain in domains:
if domain.name.startswith("e"):
if domain.domainType == 'CodedValue':
coded_values = domain.codedValues
if domain.name in modification_dates:
if modification_dates[domain.name][0] != str(coded_values):
modification_dates[domain.name].append(str(datetime.datetime.now()))
else:
modification_dates[domain.name] = [str(coded_values), str(datetime.datetime.now())]
for val, desc in coded_values.items():
ws.append([domain.name, "Coded", val, desc, ""])
else:
range_min = domain.range[0]
range_max = domain.range[1]
if modification_dates[domain.name][0] != str(domain.range):
else:
modification_dates[domain.name] = [str(domain.range), str(datetime.datetime.now())]
ws.append([domain.name, "Range", range_min, range_max, ""])
# Save the workbook including both the domains and modification dates
wb.save(xlsx_filepath)
# Save the modification history to the CSV file
with open(modification_table_csv, 'w', newline='') as csv_file:
writer = csv.writer(csv_file)
writer.writerow(header_csv)
for domain_name, modification_dates_row in modification_dates.items():
row_data = [domain_name] + modification_dates_row
writer.writerow(row_data)
# Append the new modification dates to the CSV file
header_csv_dict = {}
for i, header in enumerate(headers):
header_csv_dict[header] = i
if len(modification_dates) > 0:
for domain_name in modification_dates:
if domain_name not in header_csv_dict:
header_csv.append(f"DATE_MODIFIED_{len(header_csv) - 1}")
with open(modification_table_csv, 'a', newline='') as csv_file:
# Convert the CSV file to Excel format
wb_csv = Workbook()
ws_csv = wb_csv.active
for row in reader:
ws_csv.append(row)
wb_csv.save(modification_table_xlsx)
