I am using the Search widget and do not want to popup to appear after a value is selected. Setting the enablePopup property to false has no impact. Neither does setting enablePopup to false on the search source itself. This seems to be a bug starting at 4.27. Confirmed through the Search widget with multiple sources sample by setting enabledPopup to false and switching from 4.27 to 4.26.
Hi @Justin_Greco -
The new view.popupEnabled property (at 4.27) only disables the click event from opening the popup, but the popup is still created for the Search widget to be used.
With the view.popup changes at 4.27, you need to set view.popup = null so that the Search widget won't display the Search results in a popup. See the example here: https://codepen.io/laurenb14/pen/dyQvewZ?editors=1000
Hope this helps!
Thanks for the quick response. I did figure it had something to do with the popup changes at 4.27. Setting the view's popup to null does work in this case, but it would disable popups across the whole app, instead of just for the search widget.
The Search widget also has a popupEnabled property you can set.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#popupEnabled
So that property should still work on the Search widget?
