From what I understand, the application load the information from the config files like the Tools.xml. Now when you are working with the viewer this process alter the configuration files every time you save an application, for example the Tools.xml when you change the icon image of the tool or some other information. When you are developing there is no process that do that, the image icon (even it goes with the tool) in the developing ambient is like the config data from the tool you have to work it yourself. I hope i am not in a mistake.Hope it help.Regards, Manuel
Hi,If it does not work when you are developing (running with the visual studio) then its ok, you have to modified the Tools.xml by yourself to set up the addIn.If it does not work when you load the addIn to an app in the builder then that's a problem. Its this your case?.Hope it helps.Regards, Manuel
